How can I tell if I cracked my heads?
Old May 11, 2002 | 09:47 PM
idrag2's Avatar
Help......Cracked heads? need advise ASAP
Today I was working on my A/C finally had to put one on. But anyway I forgot to turn on my fan.....and the temp went up to around 240 or 250...I noticed it when the needle was right befor the red and the gauge ends at 260.......then I turned on the fan and used my air nozzle to blow air over the RAD. So how can I tell?
Old May 11, 2002 | 10:06 PM
idrag2's Avatar
Anyone? I need advise quick.......please help me
Old May 11, 2002 | 10:30 PM
Jza's Avatar
Jza
It's not doing anything adverse? You just got dangerously hot and that's it?
Old May 11, 2002 | 10:35 PM
SlowStangEater's Avatar
It takes more than one time at 250..........."usually". I wouldnt worry!
Old May 11, 2002 | 10:41 PM
idrag2's Avatar
Well it has been that hot once befor.........about 1 year ago. Same thing happend my dumb *** forgot to turn on the fan....and the same thing, The heater core started to rattle and I about crapped on myself
Old May 11, 2002 | 10:45 PM
I think weve all done that one once or twice If you cracked a head you would notice a big performance drop...........Dont quote me but the easiest way to check is to check for bubbles in your radiator fluid. Usually is a sign....But iit doesnt mean that its a major problem..
Old May 11, 2002 | 10:51 PM
idrag2's Avatar
Nope car still runs great............might run alittle hotter but that could be me watching the gauge more, but it still runs real good....No water in the oil or oil in the water. I think I am going to wire the fan DIRECT!!!! Then there can be no more
Old May 12, 2002 | 09:44 AM
Vader's Avatar
For about twenty-two bucks you can wire in a thermostatic fan contrtol to solve the problem.
If you are concerned about damage to iron heads at that temperature for a short time, unless you were really "working" the engine hard, don't lose any sleep. Iron is very forgiving. Aluminum might be a completely different matter, however. A short time at elevated temperatures can cause warpage.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
michealleger
Aug 26, 2015 03:29 PM
