fixing 86 IROC..have some questions
Old May 12, 2002 | 11:32 PM
TransAm85's Avatar
Hi, I am buying my friends wrecked 86 iroc. Besides the hood, rt. fender and front piece, it needs a radiator. I am going to get all of the parts out of a wrecking yard to fix it. It is a 305 tpi motor...do I have to get a radiator from a TPI car or can it be a carborated one? I don't know if there is any difference between the radiators or not...let me know! thanks.
Old May 13, 2002 | 12:43 AM
TurBo BirD's Avatar
Car: 1989 Pontiac GTA
Engine: 3.8 Turbo
Transmission: 200r4
no difference between the radiators...your good either way
Old May 13, 2002 | 12:49 PM
Bralgar's Avatar
A little different
Uh, there is one small difference, The heater hose routing. Most carburated (TBI too?) fbody's had the heater hose run to the top of the water pump,this is not possible on a TPI, no clearance. there is an extra fitting on the passenger side of the radiator in TPI cars for the heater hose to hook up. Now other than this small difference they should be the same. And really isn't a problem if you decide to not run a heater core, and you block off the heater hoses on the TB and block.
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
Amillionoh7
Aug 7, 2015 01:24 PM
Leggman1
Aug 6, 2015 04:15 AM
