can't set timing
Old May 14, 2002 | 03:37 AM
jeff85iroc's Avatar
can't set timing
I tried to reset my timing the other day and when i looked at the timing marker too see what it was i could not even see the timing marker on the harmonic balancer.
The car starts easy revs nice does not sound like it is missing while the car is standing still idling.Then when you drive the car it feels like it is missing when you give it a bit of gas but it is still driveable.
Could the dizzy be 180 degrees out?
any suggestions or comments on what it could be.
Thanks in advance
Jeff
Old May 14, 2002 | 05:41 AM
ronterry's Avatar
Car: '94 Corvette
It would'nt idle if it's 180 degree off. Believe me, we've all been there, done that. You might check your plugs, or wires. It's very common for a fouled plug or dieing wire to idle good, but under load it misses while driving.
Ron
Old May 14, 2002 | 06:08 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Put some white out on the timing mark
Old May 14, 2002 | 06:09 AM
ronterry's Avatar
Car: '94 Corvette
Shoot some engine cleaner on it first though
Ron
Old May 15, 2002 | 02:04 AM
jeff85iroc's Avatar
sorry guys
The harmonic is clean and i can see the mark on there but when i check the timing the mark on the harmonic can't be seen.
I mean when the timing light fires the mark on the harmonic is down at the bottom.Is the harmonic a 1 or 2 peice could it have slipped or something.
I hope this all makes sense.
Thanks .
Jeff
Old May 15, 2002 | 04:54 AM
Engine: 406
the balncer is ,i believe , at least 2 pieces.separated by a rubber ring...But if it came apart, you would know it. It would be trying to come through your timing chain cover. I agree with Ron, sounds like an ignition Problem to me also. T his one is kinda Strange, I think i'll leave this one to the " THIRD GEN. WIZARDS".
Let us know what you come up with.
Old May 15, 2002 | 07:17 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Did you disconnect the tan/black EST wire before checking the timing?
Old May 16, 2002 | 08:53 AM
Vader's Avatar
Old May 17, 2002 | 11:33 PM
jeff85iroc's Avatar
Yep disconnected the EST then tried to set timing then i had the problem that i stated.
Hope i don't have to but i might have to take it to the mechanic.
I will try a few things first and see what happens.
Thanks for the reply's
Jeff
Old May 18, 2002 | 02:43 PM
Vader's Avatar
If you want to stand on your head behind the radiator (or use a mirror), you can do a quick check of the timing mark on the balancer. The timing groove in the balancer outer ring should be advanced about 7° from the keyway in the crank on most SBCs I've worked with. If yours is noticably off alignment with the crankshaft keyway, the outer ring has probably slipped. It's not uncommon.
Old May 18, 2002 | 10:09 PM
jeff85iroc's Avatar
The mark is way off,what problems could this have caused and should it be making any weird noises.
Looks like i've got a job to do on the weekend.
Thanks again.
Jeff
Old May 19, 2002 | 12:54 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
After the outer ring slips for a while, the rubber wears out and eventually you have metal to metal contact. That makes a nasty sound and coats the eng with little metal shavings.
I was working on a truck (a few years back) that had a balancer self destructing. Had to remove a skip-pan to get at it. When the air from the air ratchet went inside the skid-pan, it swirled around and came back out with tons of metal shavings,, right into my eyes.
Yours' hasn't gotten that bad,, yet..
What causes it?
Probably the rubber getting old and shrinking.
Old May 19, 2002 | 06:54 PM
jeff85iroc's Avatar
Thanks guys
I think i will change the balancer before anything happens.
Jeff
Old May 20, 2002 | 05:27 AM
Engine: 406
make sure you use a installer / remover......borrow one from Autozone...At least use a hardened bolt and washers to put it back on..put a little lube on the seal to help it back on...I believe 60lbs of torque is what you want.....USE THE INSTALLER...or you risk breaking the bolt off in the crank...good luck
Do they have Autozone Down Under?
Old May 21, 2002 | 01:34 AM
jeff85iroc's Avatar
We don,t have autozone but we do have auto one and autopro maybe in some way they are linked i'm not sure,but there is no auto parts store that will lend tools.
Sometimes i wish there was though(when you need that tool you will only use once).
Jeff.
Old May 21, 2002 | 01:46 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The pullers aren't too expensive.
I bought a "middle of the road one" a few years back. k-D Tools I think.
Costs like $25 or so. I've used it a few times. Mainly for timing chain replacements.
Sydney is a big city. (been there a few times)
Maybe you could start a car tool rental business there!!
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
