Knocking Noise
Old May 16, 2002 | 01:37 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Knocking Noise
Ok my 88 TBI camaro has had this nose for a while now. It sounds like it is comming from the passanger side by the manifold. Could be an exhaust leak cause it goes away after the car is warmed up but might knock here and there. I was also told it could be my valves. What is up with that? Am I right that it is just an exhaust leak, or could it be worse. The car has 122K miles on the engine. And i'll be the first to admit I beat the hell out of this car for the simple fact I am putting my old 350 in it. When I slam the gas and it hits second the back tires spin and sometimes I get a little sideways. I love this car. What is wrong?
Old May 17, 2002 | 08:22 AM
Vader's Avatar
Would you characterize the sound more as a dull knock or a sharp tap?
Old May 17, 2002 | 08:33 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
it is definatly not a light tap i is kind of like hitting 2 pieces of metal together with cloth over them. that is a werid way to describe it but aths the best i can do.
Old May 17, 2002 | 10:42 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Dull knock = ?????
Sharp tap =?????
Old May 18, 2002 | 03:29 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Prolly and exhaust leak, as most rod and main noise doesn't go away with temp.
I also heard some noisy hp/hv oil pumps when cold.
Old May 18, 2002 | 02:56 PM
Vader's Avatar
I would characterize your description as a knock, not a tap. That could be piston slap, a rod or main bearing, or a piston pin.
How long does the engine warm up before the noise is silenced?
Old May 18, 2002 | 04:07 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Have someone power-brake eng slightly while you listen under the hood. An exhaust manifold leak will get a lot louder with a relatively small increase in throttle position.
After the exhaust heats up and expands, it can help seal the leak.
Old May 27, 2002 | 02:47 PM
Buck268's Avatar
would an exhaust leak sound metallic at all?? Cuz I got a nice little noise, sounds like 2 metal things are repeatedly smacking eachother...
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
efiguy
Sep 27, 2015 01:30 PM
