Very Basic Open Air Question (Another one)
Old May 17, 2002 | 10:10 AM
MX265
Guest
Posts: n/a
Very Basic Open Air Question (Another one). I will be getting a Mr. Gasket Open Air Filter and one of the K&N 14X3 filter elements. I have a few questions. I know the Vaccum line needs to be plugged. I know that AIC wire goes into the bottom of the new air cleaner.
1 - Do you NEED to re-program the ECM? Is this a requirement or just an enhancement?
2 - Should I get the 0-Drop Base model or the Drop base Model.
This is for an LO3 Engine in an '89 IROC.
I have found some etremely over complicated articles on this and some very basic lacking articles. Basicly, I just want to feed my engine more air. Any input is appreciated.
Thanks,
Andy
Old May 17, 2002 | 11:01 AM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
reply
All you have to do is drill a hole, or use one of the pop
out tabs if there is one, and put the Sensor in there other
wise you will get a code.,
Old May 17, 2002 | 11:52 AM
MX265
Guest
Posts: n/a
Thanks Bluebird. But the two questions that I had was:
Thanks,
Andy
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
