car runs COLD
Old May 19, 2002 | 09:58 PM
goneracin's Avatar
car runs COLD
Hi guys. My 87 l98 IROC runs about 135-140 degrees going down the hiway. The way the oil cooler return line is routed, the cooling system never is blocked completely by the thermostat, and it wont get close to the 180 degrees it should. In town, or sitting, it will heat up, but not on the highway. Is this a problem, im worried it wont go into closed loop correctly, and also, it wont get hot enuf to run efficiently. thanks
Old May 19, 2002 | 10:40 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would check to make sure your gauge is reading correctly.
Old May 19, 2002 | 11:57 PM
SlowStangEater's Avatar
Yeah, camaros guages are hardly ever accurate.
Old May 20, 2002 | 09:08 AM
Beefy89's Avatar
The gauge in my truck reads 260* when it warms up..
Old May 20, 2002 | 03:05 PM
goneracin's Avatar
i think the gauge is pretty accurate, as i have the stock chip in it right now, and the fans turn on and off pretty close to where they should. the computer uses a different sensor than the gauge, so they are close.
Bob
Old May 20, 2002 | 03:15 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My cars temp gage is getting checked wednesday for accuracy
Old May 20, 2002 | 03:21 PM
Car: 99 Formula
Axle/Gears: 342
I wouldn't drive it then.
Old May 20, 2002 | 11:39 PM
Beefy89's Avatar
If it was actually running at 260*,I wouldn't be able to drive it very far.
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
