Recommend auto store gear oil
Old May 21, 2002 | 12:03 AM
BowtieFever's Avatar
I have a SLP Posi and gears to install this week. I want to put good gear oil in it, but do not want to order from any place. I would like to just get some from a Pepboys, ABC, Auto Zone, etc. What kind do you suggest? Since I do not have a posi with clutch plates, I do not need Posi Additive, right?
Old May 21, 2002 | 12:07 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Mobil 1 gear oil, there is no substitute. What kind of a posi unit are you putting in?
Old May 21, 2002 | 02:14 PM
82camaro's Avatar
Car: 82 camaro SC
Get the best synthetic you can find. It only holds 2 quarts and probably won't be changed in a long time. I I read on this board that you should use the additive with the torsen limited slip you have, but don't have to.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
