cam or bolt ons?
Old May 21, 2002 | 10:55 PM
19WS6T/A91's Avatar
cam or bolt ons?
i have a stock 91 t/a and i was wondering if the stock valvetrain will hold up to the comp xtreme energy cam with .495/.502"lift? if not what bolt ons should i get? current mods in sig.
DAVID
P.S. no i dont have headers(i refuse to spend 450 on the slp's and i hear that the edelbrocks arent any good)
Old May 22, 2002 | 09:35 AM
Beefy89's Avatar
That cam's to big for stock springs.If you go with it I would have the heads machined for screw in studs also..
Old May 22, 2002 | 12:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And get long slot rocker arms. The computer might not be very happy with you, though.
Unless/until you get headers, you're only hurting yourself. The SLPs are the best, I went with the Hookers for the sake of economy but stayed away from the TES for the same reason you stated.
Old May 22, 2002 | 04:48 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I'm pretty sure i've read that the stock springs will only take .470 -.480 lift
Old May 22, 2002 | 06:43 PM
iroc22's Avatar
Definitely get the cam. Also get the Comp Cams 983-kit set of springs that will sit in the stock spring seats.
camaro71633
Sep 1, 2015 10:24 AM
bdads
Aug 24, 2015 06:01 PM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
