cam choice
Old May 23, 2002 | 10:05 PM
robbob's Avatar
cam choice
Buying a new cam and want an opinion on what to get of these two.
(The car is emissions checked)
Should I get the comp cams 12-234-2 or the edelbrock cam for my 305 lg4.The edelbrock set says not to use the stock timing gear,mine is new and don't want to replace it.
Edelbrock is : dur@50, intake-204, ex-214. lift intake 420, ex 442
comp is: dur@50, intake-212, ex-218. lift in-447, ex-454.
Old May 23, 2002 | 10:45 PM
GOLD85's Avatar
the reson u cant use your stock timeing set with the edelbrock cam is cause thoses basterds made the cam so u can only use and edelbrock timeing set. edelbrock cams suck ***, get the comp cams bump stick
Old May 24, 2002 | 12:29 AM
Blackened's Avatar
Care to explain why Edelbrock cams "suck ***" ?
Old May 24, 2002 | 12:53 AM
jeffs82z28's Avatar
I put in a Summit copy of the Edelbrock performer cam and a set of Flowteck shorty headers, and I'm very happy with the results.
It has a nice idle and pulls strong to 5500 rpm. I've wound it out to 6000 a couple of times but the gains were not worth the stress being put on the motor. I'm sure it would improve even more if I had a better cat and cat back exhaust.
Old May 24, 2002 | 01:28 AM
nsimmons's Avatar
you dont need a special timing chain with the edelbrock cam, i installed one in my 79 z28 and used a stock chain. worked great.
Excellent cam, i was very happy with it.
I ordered a summit 1102 which is a clone of the edelbrock performer cam for my vette, cost 71 dollars showed up yesterday. I planning on adding some 1.6 rockers. Im looking for big torque numbers 5000rpm shift point, to compliment the crossfire intake.
advertised duration is I:262 E:272, these arent listed in the catalog, the ramps are rather steep, more so than the edelbrock, i noticed this right away.
Whats your goals? I chose to build my engine around the intakes flow and trannies shift points, so the lower duration is perfect for me.
Old May 24, 2002 | 01:36 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
COMP CAM... :lala:
Old May 24, 2002 | 06:34 AM
SLOW5.0's Avatar
:hail:Comp Cams:hail:
Old May 24, 2002 | 11:05 AM
robbob's Avatar
Will these cams affect my emissions very much? I have to already buy the performer with egr and sell my regular performer because of emissions failure.
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
masonta
Sep 1, 2015 06:40 PM
