Heads for a 406
Old May 24, 2002 | 05:50 AM
92RSTX's Avatar
Heads for a 406
I need a casting number for a good set of chevy heads for a 406sb since I probably cant afford to do fancy alluminum heads...
Old May 24, 2002 | 09:18 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I'm not entirely sure, but I think all 406 heads sucked ballz. I belive they were all somg heads, and flowed like crap. You might want to save for a set of Fastburns or Vortecs if you cant afford the fancy-shmancy aluminum heads. Do a search on here for people with those heads and see what kind of power they are making, I think there are a few people running 400's with those heads.
Old May 28, 2002 | 06:44 AM
my89formula350's Avatar
041 ,,041x 461 462 086 these are all good flowing factory castings most have 165 to 175 intake runners and all have closed chamers should be easy to find paul
Old May 28, 2002 | 04:55 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
hey just FYI u totally dnt want to use thestock factory 400 block heads, specially if u want to make some power look at AFR or brodix.
Old May 28, 2002 | 08:21 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
like he said.. don't go factory
also consider
Dart
Pro-action
Canfield
23degree TFS
Old May 28, 2002 | 08:24 PM
CORKVETTE1's Avatar
i am partial to afr the single most power part you can add to a engine besides a blower turbo nos is the cyl head everbody puts all there money in to the engine and neglects the heads i would take a 305 with afr heads over a 406 with junk smogger heads just look at all the fast cars and i guarantee they all have a good set of heads on the car
Old May 28, 2002 | 08:55 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i couldn't afford expensive heads either. i think the #on my heads is 993. iran 13.4 @105 mph with the stock heads and a .447 lift cam. they'll get you by till you can save your money.
Old May 28, 2002 | 10:26 PM
92RSTX's Avatar
heads
As of now I am more than likely gonna run some Sportsman IIs on it..I just need to find out if I have to have the steam holes drilled in em
Old May 29, 2002 | 12:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm using 186 double-humps with bolt holes on my 400, with some mild porting. They came on 69-70 Impala, station wagons, Monte Carlo, and other higher-horsepower applications.
Yes, you need the steam holes, you can drill them yourself. Lay a 400 head gasket on the heads, mark them (6 per head) with a punch, drill with 3/16" drill until you hit the water jacket, which is about 3/8" or so deep.
92projectcamaro
Jan 18, 2016 08:00 AM
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
z28guy134
Sep 1, 2015 11:50 PM
