A/C Compressor & Temp Question
Old May 24, 2002 | 06:30 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
what is a good brand reman compressor? is there even one in existince? O Reiley's, Autozone, Advanced, Car Quest, & Napa carry remanned Four Seasons BS compressors. they really suck. i have gone through a couple and boy they make a loud rattling noise. my original harrison never made THAT kind of noise. it just leaked a little. i would advise to stay away from parts stores that carry Four Seasons remanned compressors. well i guess i will have to get an AC-Delco compressor if all else fails.
as for the tempeture question. for you guys with A/C(TPI Dual Fan Setup), what temperture does your car run with they A/C on? at Idle? on the freeway? mine runs around 220* idling and 180* on the freeway. i think it runs a little hot whilst idiling? what do you guys think?
Old May 24, 2002 | 07:48 PM
Hung Start67's Avatar
cooling question
hey bro i just picked up a 92 z-28 with the 350 and im trying to get a handle on the cooling system myself...here is the deal...the drivers side fan i believe is controlled by the computer to turn on at some *** awful temp..way to high from the factory...so i installed a hyper tech thermo master in the car...and the fan turns on about 180-190?...the passenger side fan is controlled by a thermal switch in the right cylinder head..to also turn on at some *** awful temp..lol...i also ordered a lower cooling fan switch from hyper tech to take care of that...also installed a 160 deg temp thermostat from hyper tech as well..had to do that because of the programming for the new chip..hopes that helps guy
Old May 25, 2002 | 01:19 AM
1986redbird's Avatar
your temps sound right on the money if you havent made any changes from stock, as far as the comp. goes, I think your right, I bought a reman from NAPA and the first one sucked, loud chattering and then died, got a free replacement from them and it is making almost as loud a noise as the first. hasn't died yet but it makes the whole car vibrate when running, what a pain.
Old May 25, 2002 | 02:51 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Your not going to find a good reman compressor at a chain store like Pep Boys, Autozone, etc.
Those Four Seasons (aka. For Siez'ons) compressors are sold under a few different names.
The guys at the aircondition.com site bulletin board recommend this site for reman compressors.
http://www.ackits.com/
Prices aren't too bad either.
Lot of good info on both sites, especially the aircondition.com site.
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Thaney9
Aug 7, 2015 08:25 PM
