Knock sensor replacement
Old May 24, 2002 | 07:29 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
Where is the knock sensor and how do you replace it? More like is it pretty easy to get too? I have access to a full lift and pretty much all the tools I need I just need to know if it is doable...thanks in advance...
Ryan
Old May 24, 2002 | 07:41 PM
wataru's Avatar
Its located on the passenger side behind the smog pump, or in that general area. If you have a lift and the tools it shouldnt be a problem.
Later Barrett
Old May 24, 2002 | 08:13 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Any chance someone has a diagram? Just so I know exactly where to look...these damn engines really intimidate me...i'd hate to screw it up by replacing the wrong sensor with the wrong sensor...Also does it need to be put in very tight? Or just snug? Any thread lock or something like that? Let me know...I appreciate it.
Ryan
Old May 24, 2002 | 09:03 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Look under the passenger side rear of the block, and youll see it. Its round, cylindrical thing usually silverish. It has one wire connector going to it. Just remember that its threaded into a coolant passage... and make sure the engine is cool. I learned the hard way.
Old May 24, 2002 | 10:19 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Thanks for the info guys...installation went very easily. Thank goodness that fixed my pinging problem...too bad it took me $140 at the dealership just to find out that the knock sensor was bad. Oh well...better than paying them the total $250 the wanted to diagnose and repair...what a rip. Took me 5 minutes and the part was only 30 bucks...how come that doesn't seem to add up to me...lol lets see 250-140-30=$80. That means that they would have been paid $80 for 5 minutes of work...thank goodness I didn't let them replace it for me...thanks again guys.
Ryan
Old May 24, 2002 | 11:30 PM
Buck268's Avatar
did you drain yer coolant???
Old May 25, 2002 | 11:50 AM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
No why? The car was cool so I saw no reason too.
Ryan
Old May 25, 2002 | 12:05 PM
Buck268's Avatar
did I spill out bad, or just a little - how 'messy' was it? I thought that the knock sensor was right in a coolant passage
Old May 26, 2002 | 12:57 AM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
it is right in the coolant passage but not a whole lot came out. Granted it only took about a minute between taking the old one off and plugging the whole with the new one. Just put a towel down on the ground and you should be fine.
Ryan
db057
Aug 22, 2015 08:17 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
gwade12
Aug 8, 2015 08:17 AM
