Rear is whining
Old May 25, 2002 | 12:14 AM
85TPITransAM's Avatar
Rear is whining
Hey, anyone that can help me? When I crank up the car, i hear a whine from the back hatch. it continues when I'm on the road, but is only noticable when the car is in park or at an intersection. Please help....I really need it. Thanks in advance
Old May 25, 2002 | 12:27 AM
phineas's Avatar
It could be your in-tank fuel pump on it's way out. Try and listen close and see if it's coming from that area (center of the hump in the rear). That's about the only thing I can think of that's moving in the back at a stop.
Kyle
Old May 25, 2002 | 12:31 AM
Ok.....well..I'm not a car expert, but does that mean that I'm gonna have to replace the in tank pump? Please help me
Old May 25, 2002 | 08:41 AM
urbman's Avatar
yes
Old May 25, 2002 | 11:39 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Could it be a hatch motor?
Old May 25, 2002 | 02:17 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
My guess would be fuel pump, but sometimes the hatch motor gets stuck on and will run forever. The previous owner of my car took the motor out and made it completely manual because the motor would run even after killing the ignition and it would drain his battery.
Old May 25, 2002 | 02:20 PM
Hatch is a Manual...so I'm guessing that it is the pump....awww damn....thats gonna be a pain in my @$$
Old May 25, 2002 | 02:43 PM
wataru's Avatar
About 2 weeks before my fuel pump went out I kept hearing a whine coming from the hatch. It was actually more like a humming noise. Your sure its not coming from the differential? Or somewhere else?
Later Barrett
Old May 25, 2002 | 07:18 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I'm not sure about the stock pump but the edelbrock EFI system came with an eletric fuel pump that has a GM part number and it consanally whines and it's been running since september with no fuel pump problems and my dad has a rustang and it's fuel pump is alawas wining and he's had it for 3 years.
Old May 26, 2002 | 10:59 AM
Vader's Avatar
A noisy fuel pump isn't necessarily a bad one. A test of pressure and flow will reveal a lot more. I had a noisy pump on one TBI vehicle for over four years, but it flowed well and made pressure. I waited for it to quit, but it never did. It's possible that the tank has shifted and the noise is now being amplified by the body and floor pan instead of being isolated.
Old May 27, 2002 | 05:03 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Might help to keep your fuel level above 1/4 tank also. I had one get real noisy on the bottom half of the tank....
Old May 27, 2002 | 01:33 PM
breathment's Avatar
this is good new to me then.. Mine has been loud enough to be heard over my exhaust both inside and outside of the car.. however you have to know what to listen for to hear it, its still loud. but pressure is good.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
chazman
Aug 22, 2015 02:01 PM
