Key won't turn to engage starter
Old May 26, 2002 | 06:03 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
For some reason today, my key won't start the car. I can put the key in and turn it until it is just about to engage the starter, then the key won't turn any farther and the starter obviously won't come on. WTF is that about?
Old May 26, 2002 | 06:12 PM
idrag2's Avatar
Maybe the ING. switch moved on the colum or the rod that works the switch has popped off?
Old May 27, 2002 | 07:43 PM
ede's Avatar
ede
i'd guess a bad lock cylinder, the thing the key goes into, easy to replace, and cheap, as long as you don't have VATS
Old May 27, 2002 | 08:08 PM
Slackett's Avatar
Igition tumblers....
Mine did the same thing.
You didn't mention milage but if it's high, the tumblers in the switch are probably worn out.
If it has VATS, take it to GM and they'll repair it stock for a small fortune.
Or do as I did. Buy an aftermarket switch.
Step by Step:
1. Remove the old switch, cut the 2 yellow VATS wires, be sure to leave about 3 or 4 inches of the wires on the old ignition switch.
2. Look under the dash (by the brake pedal if I remember right) and find the other end of the two yellow wires there, pull those wires out of the steering column.
3. Re-connect the yellow wires, electric tape them together, put your old key in the old switch and stow the whole thing under your dash panel.
4. Install the new ignition switch just as you any other non-VATS switch.
Piece of cake. Your VATS isn't disabled, you just always have a key in it. I have seen some guys mount the old switch in the dash so they could remove the key whenever they wanted, thereby 're-enableing' the VATS system.
Old guys....comments/better ideas?
RB
Derick15
Sep 17, 2016 05:28 PM
L98GTA87
Aug 25, 2015 02:23 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
