How much power gained from windage tray???
Old Jun 7, 2002 | 11:35 AM
Momar's Avatar
I was wondering how much power you will actually gain from a windage tray. Also do they make any good ones to fit the stock oil pans?
Ben
Old Jun 7, 2002 | 11:57 AM
ede's Avatar
ede
none, but you won't lose any either and that's what it's really made for
Old Jun 7, 2002 | 12:24 PM
Momar's Avatar
Ok, how much power can it keep you from loosing? Is would it be worth getting if my motor will be out anyway?
Ben
Old Jun 7, 2002 | 12:54 PM
Jester's Avatar
it depends on how high you spin your motor. Usually around 5-7 hp..I think I saw one gain 14 once but it was a 7000rpm big block.
Old Jun 7, 2002 | 01:44 PM
Momar's Avatar
I wish I had a 7000 rpm big block. I dont think mine will go above 6000 really. My cam is supposed to peak at 5800. Is there a brand I should get? They do make them that will work in the stock oil pans dont they?
Ben
Old Jun 8, 2002 | 09:53 AM
Vader's Avatar
To really do it right, custom fit strippers are a little better than a windage tray alone. One big advantage is that at sustained high RPM you don't get nearly the foaming that you might without one.
Old Jun 8, 2002 | 05:45 PM
DSaylor's Avatar
I bought the moroso kit for $35, it had a windage tray, crankshaft scraper and a baffle for the back of the pan by the oil pump. It all fit on a stock pan.
Have to use main studs with it too. I got the ARPs for around $40, i think, good insurance though.
They say it doesn't make noticeable power on mild engines, but I thought the parts made sense and for that low of a price, its worth the piece of mind.
Old Jun 8, 2002 | 06:09 PM
Momar's Avatar
So it only cost 40 dollars for the main studs? Are the studs stronger than just using bolts? Sorry, this is the first time I have really done much to a motor intearnally.
Ben
Old Jun 8, 2002 | 08:30 PM
DSaylor's Avatar
Everything I read before I did it said the studs were stronger than bolts, and ARP is the only brand I use inside my engine.
BRoss99
Aug 10, 2025 05:08 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
