jasper engines???
Old Jun 7, 2002 | 08:34 PM
89droptop's Avatar
jasper engines???
has anyone ever delt with jasper engines??? i was thinking of purchasing one but i dont want another stock motor. but the warranty is unmatched. Thanks
Old Jun 7, 2002 | 08:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
From what I hear, they're not bad. I got my GM Goodwrench with a 3yr/50k mile warranty.
Old Jun 8, 2002 | 09:58 AM
88ROC1LE's Avatar
Jasper engines and tranny's have strong local support, as it is only an hour drive to Jasper from here. Alot of the superpro guys at the track like the Jasper work, especially their trannys. I have one of their TH350's in my cutlass and I have no problems. I would say their engines are just as good....IMO
Old Jun 8, 2002 | 10:11 AM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Jasper was the only ones we used for engines and outdrives at the boat shop and we never had a problem with anything of theres.
Old Jun 8, 2002 | 07:51 PM
89droptop's Avatar
can the engines be special ordered to what you want or are they all just stock???? I would like to buy a chevy 502/502 and i was just wondering whether jasper would do that or not. Thanks for all the help.
Old Jun 8, 2002 | 09:50 PM
Car: 99 Formula
Axle/Gears: 342
Not sure if it's what you want. But check in the Jegs catalog, I believe they carry a crate 502.
Old Jun 9, 2002 | 01:31 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
We are a Jasper dealer where I work. Most of their engines have a 3 yr / 75k mile warranty. The send the engine to you broken in so you drop it in and go.
I think you can also call them up and have them put in different cams and stuff...but that of course costs more. I also think that if you pick a cam from a list they have it'll still be covered under warranty but you'd have to double check that info.
I just put a Jasper 454 in this panel truck at work. Runs good...but alas the truck is too heavy for a good smokey burnout
Old Jun 9, 2002 | 08:34 AM
89droptop's Avatar
thanks that is what i wanted to know. I know jegs has one but around here it is alot cheaper to have a jasper engine installed. Because of the warranty. Thanks though i guess i will have to contact them and ask them the questions.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
