View Poll Results: Should I have my 305 rebuilt with performance parts, or should I swap in a 350?
305! It's a healthy engine and you will save money. If you do it right you'll have plenty of power, don't listen to the 350 guys!
30.00%
350 all the way! You'll spend more money on that 305 than you would on a 350 for the same power.
70.00%
Voters: 20. You may not vote on this poll
Rebuild/Mod the 305 or swap the 350
Old Jun 11, 2002 | 09:56 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Bang for buck.
Should I have my 305 with 183k miles rebuild with high performance parts, new cam, etc. etc. or should I swap a 350 in it? I know a lot of you are going to scream 350 but my grandfather (who races Vettes ) insists that I should have my 305 TPI rebuilt. Gimme some suggestions, pros/cons, etc. He knows someone (who is currently working on my grandfather's 63 Corvette split-window, :: drool :: ) that would be able to do pretty much whatever I wanted. I tell him what I want installed and he'll do it, and he can be trusted. I'd much rather have him do it over some shop I don't know. I'm looking for what would be best for the money. I don't need a 900HP monster, I just want something that I can take to the track and have fun with. Still will be street driven though. If I rebuild, what kind of parts should I have installed (cam, etc.) so that I have room to build on it and increase power with addons without having to worry about tearing the thing apart?
(P.S.- I would have posted this in the Motor Swap forum, but obviously, they're the ones who would swap, so I need a more unbiased opinion. )
Old Jun 11, 2002 | 11:17 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I say do a 350 ONLY because you are stuck rebuilding the 305. It has been shown quite convincingly by board members that it is economically better to stick with the 305 as long as you have a good short block.
But since your short block requires work, it is much better money-wise to rebuild a 350 junkyard block.
Your grandfather probably wants you to learn to race with a smaller engine until he is satisfied you have the experience not to harm yourself.
Old Jun 11, 2002 | 11:21 AM
FyreLance's Avatar
What says there is anything wrong with my block?
Nah, I don't think that's the deal with my Grandfather, we were also discussing what things we could do to increase the horsepower on the thing. I think he's looking more for reliability, ie he feels more comfortable with a rebuilt engine from a guy he trusts as opposed to a used engine which we have no idea what kind of abuse it has taken.
Old Jun 11, 2002 | 02:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
How much are you looking to spend? I would say look into some crate 350s, but that's just me. I got my 350 with a 3yr/50k mile warranty. Though it needs a cam swap bad, the stock one is horrible. I only paid $1290 for it delivered.
Old Jun 11, 2002 | 02:08 PM
Matt86t/a's Avatar
hey Mark, where did you find a crate 350 for that little? Was it used? I could use one for that cheap.
Old Jun 11, 2002 | 02:58 PM
Car: 99 Formula
Axle/Gears: 342
No, it wasn't used. Everything is new on it. I believe i got it from www.greenwoodchevy.com just look for the GM Goodwrench. I must warn you though the cam in it must be changed if you want speed. It has a 390/410 lift and stops power at 3500 rpms. I was recommended the Comp 268XE for it.
Old Jun 11, 2002 | 03:20 PM
Matt86t/a's Avatar
wow those are nice prices. You got the universal one? It says pre '85 though. What would be good for me?
Old Jun 11, 2002 | 05:13 PM
Car: 99 Formula
Axle/Gears: 342
What the pre 85 means, is it is a one piece rear seal I believe. All I had to do was get a different flywheel and it works.
Old Jun 11, 2002 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pre-'85 means two-piece rear main seal, actually. And "straight" intake manifold bolts.
You said you were going to rebuild the 305. That typically means bore cylinders, new pistons & rings, turn crank, new bearings. Perhaps that isn't what you meant.
I agree with SB, if you DO rebuild a shortblock, don't do it on a 305. However, you can get a good bang-for-buck, hard-running 305 without touching the shortblock if it's in good shape. See sig for what I mean.
Old Jun 11, 2002 | 06:23 PM
Car: 99 Formula
Axle/Gears: 342
I always get that mixed up.
Old Jun 13, 2002 | 09:59 AM
FyreLance's Avatar
Wow, I'm actually surprised, I figured more people would say rebuild than just one.
Old Jun 13, 2002 | 11:13 PM
iroc22's Avatar
Straight manifold intake bolts were 1987. I'm sure you know this, just trying to not confuse someone who doesnt know.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
