real high idle from carb spacer?
Old Jun 17, 2002 | 02:28 PM
82T/A powah's Avatar
i just finshed installing a 4 hole 1" carb spacer on my car, after i was done, i went to start the car and the RPM's right away shot up too 2500, then started to get higher when i would try to kick it down.. any ideas what coulda happened here? could i off buger the idle on the car somethin?
any replys would be great
thanks
Old Jun 17, 2002 | 02:34 PM
ATOMonkey's Avatar
Sounds like the secondaries on the carb are cracked open. Make sure the linkage is ok. Make sure the primaries aren't open either. If you think it's the electric choke unplug it.
Old Jun 17, 2002 | 03:20 PM
i checked the carb, just after i started the car and the rpm's were starting to rocket up, both the primary and secondarys were closed.. now as far as checking linkage on the carb.. what should i look for.. it looks to be all hooked up proper.. the only thing i can see that mite not be tight is a line that feeds into the back of the carb, same kinna line that you have for fuel.. i losened that to get the carb higher for the spacer to fit under.. not i tightened that line a little, but not quite as tight as it was before... anyone know what that line is and if it would cause my problem..?
Old Jun 17, 2002 | 03:44 PM
1986redbird's Avatar
I believe that line goes to your power brake booster and is a vacuum line. you may want to disconnect the throttle linkage comming from the gas peddle and try that, also try disconnecting the possitive battery cable for a few minutes then reconnect it and try that (assuming its a computer controlled carb), I'm not sure that a vacuum leak would cause the problem but it can't hurt to check all the vacuum line going to the carb and make sure they're tight and in place.
Old Jun 17, 2002 | 05:04 PM
well i tryed unpluging the battery for a bit and the trottle linkage.. didn't help.. the sound it makes is a weird boging sound now and a little black is actually coming out of the exhaust... is it possble that i could knocked out the idle or mixture settings? or maybe the spacer is blocking something..?
Old Jun 17, 2002 | 05:18 PM
i also had my fuel filter out, is it possbile i put it in backwards? and thats whats causing the problem?
Old Jun 18, 2002 | 12:41 PM
is it possible that when you were moving things around you turned your distributor accidently, you may want to try checking your timing.
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
