passenger power window prob. HELP!!!
Old Jun 18, 2002 | 06:30 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
whats up guys, today I found out that I have a problem w/ my passenger side power window-it'll go up or down but at some point it'll stop, then you have to wait about 10 sec before I can put it up or down(I found this out, its almost like it needs time to power up or something)
has anyone had this problem before? if so what do I have to do to fix it? get a new motor? cause thats what I was thought was the problem-it can't be any faulty wires cause its getting the signal(to go up or down)
thanks for any help guys
Old Jun 18, 2002 | 09:02 PM
2vmodular's Avatar
sounds like the the motor is drawing too much current and engaging the thermal circuit breaker. once the breaker cools off, the window will move a little bit again.
could try replacing the brushes inside the motor. more details and some pictures are avaliable at:
http://www.geocities.com/modularmoto...n/powerwindows
Old Jun 18, 2002 | 09:36 PM
Swapmaster's Avatar
Time for a new motor. Remans are cheap.
Old Jun 19, 2002 | 08:48 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, when the motor needs replacing, they overheat,then you have to let it cool off before it'll move again.Got the same problem on my wife's blazer right now. Replacing it's a pain in the a**, but motors are cheap now.Got mine at Pep Boys for about $45.
Also, recently found a place called Lowesville Automotive Warehouse
(800) 428-3522
They just quoted me $34 each for New Blazer Window Motors!
-Rich-
Old Jun 20, 2002 | 11:12 PM
91fbirdgta's Avatar
thanks guys for the info., before I spend any money on getting a new motor, what do you think about lubing the motor w/ either silicone or a cleaner type substance to "revive" the current motor?
Old Jun 21, 2002 | 12:03 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
dont be a jew.......get the new motor.......youll be greatful later......
Old Jun 21, 2002 | 11:56 AM
2vmodular's Avatar
if you're looking to "revive" your motor, try changing the brushes, often fixes problems similar to yours. new brushes should be under $5.00 for a set.
Old Jun 21, 2002 | 01:32 PM
91fbirdgta's Avatar
I'll try that w/ the brushes first, and if all else fails I'll get the new motor . . thanks
and 83CAMAROMAN- I'm no "jew"
Old Jun 21, 2002 | 02:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Same thing happened to my dad's chevy truck; the window woudl go up a bit, then stop. A bit later, you could raise it an inch, and it would stop. A new motor fixed it. We bought one out of JC Whitney for $60, same motor as our Firebirds use, by the way. The thing was either new, or it was cleverly rebuilt- the case was stamped GM! Replacing it was, of course, a pain, but definatly doable. Make sure to read up on it; you need to drill thru the sector gear and bracket, to put a bolt in it, because otherwise, if you just drill out the motor rivets, the spring in the regulator will explode on you. It's no big deal (you can drill the sector gear anywhere, and use any bolt through the bracket & gear to keep it in place). We actually removed his regulator (small little thing compared to ours!), and replaced the motor on the bench. We reattached the regulator to the doors without using rivets. We did the same thing I had done on my Firebird. (My power doors rusted out, I put my power internals into rust-free non-power doors.) I used a fat & short bolt, which filled up the entire rivet hole, slapped some red loctite on the threads, and used a lockwasher and nut on it.
Oh and honestly, if you're going to go thru the hell of replacing the brushes, you might just want to replace the motor! Maybe keep the old motor in case you ever need parts. JC Whitney didn't ask us to send the old core in, which makes me think that they might've really been new motors.
Old Jun 21, 2002 | 07:14 PM
2vmodular's Avatar
replacing the brushes is considerably easier than replacing the entire motor assembly because the motor does not need to be removed from the door.
are other things that can go wrong with a motor besides just the brushes wearing out. so replacing the brushes may not fix the weak motor, but it often does.
Old Jun 22, 2002 | 01:47 AM
Axle/Gears: 3:08
im sure your not.........just puttin in my two cents worth........i see your in bergen county.......we aint so far from each other.....im new to nj......dont like it though..........cya
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
evan555222
Aug 22, 2015 07:14 PM
