Clunking noise from Right Front tire
Old Jun 19, 2002 | 10:42 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Me and a friend changed my rims and tires to the 91-92 camaro rims. My friend put the jack on the steel beam for the front suspension and started jacking it up. We heard a thud noise and the car dropped a bit but did not fall off the jack. We checked visually for anything broken but nothing visable. Then we drove the car and a clunking noise was coming from the right front tire area. It happened while driving staight and was more noticable when turning right. We checked for rubbing and nothing noticable. Any ideas. Thanks
Old Jun 20, 2002 | 09:00 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I've had "clunk" noises that turned out to be several different things. A bad Caliper, A-Arm Bushing, Ball-Joint, Idler Arm, you name it. It'll get easier to find as it gets worse.(I know that's not much comfort, but I'm just being honest)
With stiff springs it can be difficult to find where the loose part is, since everything's under so much tension.
Keep poking around and you'll find it sooner or later....hopefully before something breaks.
Good Luck.
-Rich-
Old Jun 20, 2002 | 03:48 PM
Camrs89's Avatar
Yeah, i just drove it home (about a block) and parked it. I have another car to drive so I'll check to see what I can find tonight.
Old Jun 21, 2002 | 01:45 PM
Camrs89's Avatar
Well, i replaced the passenger side rotor and inner/outer bearings. It still makes the noise when you crank the wheel to the right but its not as loud. It makes the sound about once for every time the wheel turns. Sounds more like a rubbing sound than metal hitting something. Any ideas?
Old Jun 22, 2002 | 08:54 AM
Vader's Avatar
Check the clearance between the inner bead of the wheel and the caliper and steering arm. You'll probably have to look with the car sitting on the ground to check thoroughly for all clearances.
Check the wheel balancing weights to make sure they are not hitting anything.
Old Jun 22, 2002 | 05:46 PM
HrdRockA4305's Avatar
"Check the wheel balancing weights to make sure they are not hitting anything"
They are VERY VERY close but I can't tell if they're hitting. I guess there would be a nick or something visible if it were, but I didn't have much time and wasn't dressed to be crawling under a car at the time.
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
Dialed_In
Aug 20, 2015 01:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
