oil leak. please help!!
Old Jun 23, 2002 | 07:14 PM
1987IROC's Avatar
hey guys i'm new here. i just changed my oil and now oil is dripping from right next to the oil filter after i start the car. any ideas? it's not coming from the drain pan or the filter itself, and i'm pretty sure it's not the engine gasket because i don't see any leak near the top. i did not use synthetic, just that new mobil 0 clean oil or whatever and i threw in some STP oil treatment too cuz the oil hasn't been changed in a while. could that be the reason it's leaking?
Old Jun 23, 2002 | 07:30 PM
ede's Avatar
ede
look at the oil sender above the oil filter, valve cover gaskets and the oil sender next to the distributor
Old Jun 23, 2002 | 08:11 PM
1987IROC's Avatar
okay i will take a closer look tomorrow to find out exactly where the leak is coming from
Old Jun 23, 2002 | 08:17 PM
MdFormula350's Avatar
I dont want to flame you but did u make sure that when u took the old filter off that none of the gasket was still on the oil pump?
also did u put a small amount of oil on the new filter?
and also did u make sure that u tighten the new oil filter snug on the pump?
Old Jun 23, 2002 | 09:28 PM
breathment's Avatar
or that you didn't overtighten it. don't turn it more then one full time around the filter seats to the housing..
that and don't use Fram filters
Old Jun 23, 2002 | 09:45 PM
1987IROC's Avatar
i am pretty sure that none of the gasket was still on the oil pump but i will check the filter again just to make sure. and i tightened it by hand maybe a little too tight and i used a bosch oil filter, i know fram is crap. anyway i'll check it out tomorrow, thanks for trying to help, you guys respond pretty quick around here
Old Jun 23, 2002 | 10:24 PM
Chevy83Z28's Avatar
Why do you guys say not to use fram? That's all my dad and I use on our cars and oil changes still come out with clean oil... what's wrong with them? Do they not flow enough or not filter enough or something?
Old Jun 23, 2002 | 10:47 PM
Morley's Avatar
There was a review on oil filters a while ago, and Fram did poorly, very poorly.
Old Jun 23, 2002 | 11:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
fram BLOWS. That stupid grip thing is the only thing they got going for them. I just stick w/ good ol' ac delco.
Old Jun 24, 2002 | 02:54 AM
rezinn's Avatar
I've cut the popular filters apart and fram does have the smallest surface area inside. I use regular ac delco filters. It really doesn't matter all that much what filter you use as long as you change it and the oil regularly.
Old Jun 24, 2002 | 04:07 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Do you guys get your AC Delco oil filters at NAPA or somewhere like that,or do you have to go to the dealer.Years ago I used to get them at K-Mart and they were very inexpensive.I have been using Fram for a while now,I did not realize they were crap.
Old Jun 24, 2002 | 02:29 PM
Car: 88 Camaro SC
Engine: SFI'd 350
the ac pf35's and the pf1218's are like 3.99 at most places. I got my pf35 for like 3 and change at the local pep boys.
Old Jun 24, 2002 | 06:38 PM
1987IROC's Avatar
okay guys i found out where the leak is coming from. it's that hose which plugs into right above where you screw in the oil filter. what is that called? anyway that hose is where it's leaking, the hose is cracked open and i can see that there is two wires in there and an orange connector thing on the end. so now my question is do i just replace the connector part or the whole hose. i can't find where that hose begins there's just not enough room back there even using a flashlight. please help, i want to get this car running
Old Jun 24, 2002 | 06:53 PM
1987IROC's Avatar
okay guys i did a search (guess i should have done that first) and i'm pretty sure that the leak is coming from the oil pressure sender where it it plugs in to the housing above the oil filter. is there anything i can do to stop it from leaking oil??
Old Jun 24, 2002 | 08:18 PM
1987IROC's Avatar
TTT
Old Jun 25, 2002 | 11:33 AM
breathment's Avatar
did u try tightening it..
u might wanna try adding some teflon to the threads. but u might end up needed a new sensor, I had one go bad once and it leaked from the end of it, not where it screws in..
Old Jun 25, 2002 | 11:46 AM
ede's Avatar
ede
damn just like i said a long time ago, buy a new one for 10 dollars or so and replce it, the sender, there's nothing wrong with the wire, as far as an oil leak goes.
Old Jun 25, 2002 | 08:07 PM
1987IROC's Avatar
are you sure it's the sender i have to replace? i went to autozone and they said i should just replace the oil pressure switch. anyway i'm gonna replace it and wrap the sensor in teflon and hopefully it should work
Old Jun 25, 2002 | 10:50 PM
Chevy83Z28's Avatar
I'm pretty sure they're both the same exact part, just one works with an idiot light in the dash while the other will work with a gauge in the dash. Just make sure you get the corresponding unit for whichever oil pressure indication you have in your dash.
Old Jun 26, 2002 | 12:01 AM
Blackened's Avatar
" dont want to flame you but did u make sure that when u took the old filter off that none of the gasket was still on the oil pump?"
What are you talking about ? What "oil pump" ? The filter doesn't screw on to the oil pump !
Old Jun 26, 2002 | 07:10 AM
ede's Avatar
ede
sender/senser same name same part. the one above the oil filter is for the fuel pump the one buy the distributor is for the gauge. one is a double hex and the other has a square for a wrench. the one above the oil filter is sort of bell shaped, with the square on it.
Old Jun 26, 2002 | 03:01 PM
1987IROC's Avatar
yeah it's the one above the oil filter i am replacing. thanks for the help dudes
Old Jun 27, 2002 | 12:42 PM
1987IROC's Avatar
hey just wanted to let you guys know that i replaced the oil pressure switch and it was easier than expected and only took me about 10 minutes using a wrench and a deep socket. anyway the oil leak has been fixed woohoo!! okay not that anybody cares anyway. now let's see what problem i will have next. i guess it's always an adventure with these cars
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
