Guideplates on stock 416's
Old Jun 24, 2002 | 07:13 PM
NTChrist's Avatar
Hi,
I've got a pair of 416 heads that are about to come back from the machine shop after being cleaned and magnafluxed.
If I'm correct, these heads should be pre-self aligning rockers, right?
I believe they made the switch to SA rockers when the intake bolt hole angles changed to the newer style(or somewhere in that vicinity).
These heads came with no guideplates or rockers (self-aligning, or otherwise), so I'm unable to tell what type of valve-directing they used on the last application.
Looking at pictures of guildplates (what I'm guessing came stock), I can't figure out a way for them to be secured to the head without the use of screw in studs. Am I missing something?
What am I supposed to use to secure the valve? Self-aligning rockers, or guideplates? What came stock on the heads.
I've tried a search, but was supplied with no answers.
Feel free to post as much info as you're willing to spew.
Thanks!
Old Jun 24, 2002 | 07:53 PM
ede's Avatar
ede
you need screw in studs for guide plates
Old Jun 24, 2002 | 08:01 PM
NTChrist's Avatar
So the heads came stock with self-aligning rocker arms, I'm guessing?
Thanks for responding, ede.
Old Jun 24, 2002 | 08:03 PM
Guest
Guest
Posts: n/a
Take a look at the pushrod hole.
Old Jun 24, 2002 | 08:19 PM
NTChrist's Avatar
I don't need EITHER guidplates, OR self-aligning rockers?!?!
That's music to my ears.
I'll buy a set of hardened pushrods, thanks!
Old Jun 25, 2002 | 09:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't even need hardened pushrods. They are recommended for use with guideplates. Won't hurt anything to use them, though.
If you're using 1.6:1 rockers, you may need to elongate the pushrod holes a little. There's a tool avaiable to do that.
Old Jun 25, 2002 | 09:41 AM
NTChrist's Avatar
I have a LT1 roller cam, and a set of 1.6 stamped steel rockers waiting to go on the heads. This will take me to about 0.480" lift, so I will check for binding with the pushrod holes when the heads are on the car.
Anybody have any idea what an acceptable clearance between the pushrod, and the pushrod holes are?
Thanks for the info, five7kid.
Old Jun 25, 2002 | 09:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Push rod hole clearance is not teribly critical, it's usually around .015". With 1.6 rockers you risk having the push rod bind at the of the hole end closer to the stud. It's impossible to guess whether it will happen to your engine or not; about half of all heads I've put 1.6 rockers onto had interference on at least one hole; and sometimes all the holes on one head of a motor interfered, and all the holes on the other head on the same engine were OK. I don't even bother with checking them any more; if the heads are off, I just go ahead and deal with it before I assemble the motor, it's less trouble in the long run. You either need to elongate the hole, you can get a "Louis tool" from Comp for doing that; or hog them out and change to guide plates. I usually do the latter. Although, those weak stamped sheet metal rockers will probably protect the rest of your valve train from any stress, by flexing and otherwise failing like they always do.
Old Jun 25, 2002 | 11:49 AM
NTChrist's Avatar
LOL
Yeah, I picked stamped steel because they can be bought for $66, out of Summit's catalogue, versus the $150+ for full roller 1.6 rockers.
I'll look into the tool from Comp Cams, thanks everybody for your help!
Old Jun 25, 2002 | 12:00 PM
iroc22's Avatar
88-up rockers were self-aligning.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
