Wierd vibration after put new tranny mount in.
Old Jun 25, 2002 | 12:08 AM
Stormshadow GTA's Avatar
I get a weird vibratioon around 2500-3000rpm ever since i tossed in my new tranny mount,what could it be.I put it in right.except for the vibration the shifts fell much better
Old Jun 25, 2002 | 01:32 AM
urbman's Avatar
Did you do this in conjunction with fresh motor mounts ?
If not you may have changed the pinion angle enough
to induce a driveline vibration....
Check your pinion angle...
If it is pretty mild it could be some driveline vibration
that was always there that is now magnified
In that case still check the pinion angle but also
have the driveshaft balanced.
Old Jun 25, 2002 | 08:40 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I recently read on another board that the poly tranny mount is 1/4" too high. This causes pinion angle problems and vibration.
Old Jun 25, 2002 | 11:27 PM
urbman's Avatar
All of the ones I have looked at were the same size
as a stock replacement unit. However as the stock
motor mount / tranny mount system ages they sag.
Roughly in equal amounts give or take a bit.
Changing motor mounts is a pain but its just "work"
Nothing clever or interesting about it.
Old Jun 26, 2002 | 11:15 PM
Hung Start67's Avatar
vibration
hey bro same problem here..original mount was toast..so went with new poly unit..low and behold..vibration..out the ying yang...went back to orig rubber mount,,much much better but still have some vibration..looking at the drive shaft now with glaring eyes..lol..later bro
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
