Built my own ram air now running rich
Old Jun 26, 2002 | 06:04 PM
Gta-Paladin's Avatar
I built my own ram air, could i have damaged the MAF maybe when i was rigging it up? Any ideas?
Old Jun 27, 2002 | 11:11 AM
Vader's Avatar
That's possible, but the ECM watches the MAF pretty closely. Any errors from no signal or signal out of range for more than 600mS will lock a DTC.
It's possible that the ducting is directing the air toward the cetered sensing tube and skewing the readings artificially high. This situation would be compounded with a MAF that had no intake side screen (which is one of the main reasons a screen is put there in the first place).
Old Jun 27, 2002 | 10:27 PM
Vader's Avatar
I wouldn't expect the same kind or degree of problem with a MAF screen removed from the outlet side, but they both perform a similar function.
Air filter condition should really be irrelevant in this situation, unless it is so clogged that the air is heavily restricted.
Old Jun 28, 2002 | 01:16 AM
What about a bad fuel pressure switch
Old Jun 29, 2002 | 08:36 AM
Vader's Avatar
The switch itself shouldn't be a problem, but the regulator might be an issue. A quick fuel pressure test would answer some questions.
Old Jun 29, 2002 | 09:58 AM
Ok so i've found a blue wire that runs the length of the car along the drivers sider rocker and originates from the trunk my hayes says it can be the fuel pressure sender or pressre switch.. the thing is the wire runs into the fuse box "area" and is then severed.... i most likely did this with my feet... Where is it supposed to connect to?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
squiggy2
Aug 9, 2015 09:30 PM
