Everybody please read. (Porting questions)
Old Jun 26, 2002 | 11:21 PM
87transam5.7tpi's Avatar
Ok I am porting my intake base, and plenum this weekend. I just want to do it right before I do it. I have done search after search and decided on this.
Siamesing the runners on teh base about 3 inches in. matching gaskets to the base/runners and runners/plenum and smothing out the divider's on the plenum where the runners go. and cutting down the EGR walls at the front of the pelum.
do you think that will be good about to port? thanks
Old Jun 27, 2002 | 02:32 AM
rezinn's Avatar
When you get inside of the plenum you'll be able to see what needs to be done. Seriously, it is obvious. You're siamesing the base, right? Yeah, that is good. 3 inches is taking out a lot of meat, you'll see when you get down in there I guess. I'm not sure if anyone has figured what the best to do on a stock engine is, so good luck with that.
Old Jun 27, 2002 | 10:57 AM
ttt
toones
Jan 6, 2016 06:00 PM
podiatra
Aug 31, 2015 09:53 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
