-=Forgot to fill the Torque Converter=- What should I do?
Old Jun 27, 2002 | 09:35 PM
Bill Kirsch's Avatar
Fired up my motor tonight... After a few, I heard a squeeking sound coming from tranny. realized I forgot to put in fluid in TC.... what should I do?
Bill
Old Jun 27, 2002 | 10:09 PM
EvilCartman's Avatar
Car: '82 Z28
Pull it out and see if there's any metal shavings
Old Jun 28, 2002 | 05:09 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The transmission pump will fill the torque convertor up for you. Just keep an eye on the fluid level.
Old Jun 28, 2002 | 05:37 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yeah most reccomend adding 1 quart to the Tc before install, but as said , it should fill up...if the noise continues I would make sure the TC is positioned correctly. It may not be all the way on.
Old Jun 28, 2002 | 06:37 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
It isn't nessesary to fill your converter before installing it. it's recommended though.
the fluid will flow into the converter on it's own when you top up the trans
Old Jun 29, 2002 | 09:45 PM
Thanks guys! The TC is ok, turns out the sound was the flexplate hitting the starter gear!! An 1/8" shim fixed it!
Bill
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
