Gas pedal sticking!!
Old Jun 28, 2002 | 11:05 AM
cllimp101's Avatar
I have a 85 x tpi and when the car is not running the gas pedal is normal or it isnt hard to push it is preety soft. But when u start the car the pedal gets extremely sticky and it is very hard to push it down. Anyone know why it is doing this. thnx
Old Jun 28, 2002 | 03:00 PM
howardhughes's Avatar
check the throttle plate for black sooty build up.if it's there clean it.
Old Jun 28, 2002 | 09:37 PM
2vmodular's Avatar
also examine where the throttle shaft goes through the throttle body. if this area is worn enough, it can cause the gas pedal to stick.
Old Jun 28, 2002 | 09:43 PM
cllimp101's Avatar
thnx guys i checked the back of the butterflies and i did clean them even thought there wasnt mush there buit it is still doin it the same amount. I was talking to someone and he said it might be the radiator fluid that goes through the trottle body. and he said u can just bypass it, and ceing i am in florida i dont need to worry about it freezing. Well i am going to go get a hose connector tommaro and see if it works. Thnx
Old Jun 28, 2002 | 10:36 PM
Z_Ghost's Avatar
I had that problem, until the cable broke.
Old Jun 29, 2002 | 10:20 PM
IROC57TPI's Avatar
yup. sounds like a bad cable to me.... they get frayed inside causing it to stick.
They're cheap and easy to replace so just do it
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
