HELP! Chugging\Surging
Old Jun 28, 2002 | 03:22 PM
OfficialIrocer's Avatar
89' IROC 5.7 TPI
leans out when holding a hgh steady rpm. o2 sensor transistions stick, shows 6 grams air flow, idles very rough and "surges" up about 1000 rpm randomly (like once a minute). Replaced both MAF relays, checked MAF - ok. Replaced fuel filter with known good one.
It just recently blew an intake gasket due to overheating\too much pressure which has been repaired (both overheating problem and intake gaskets). It WAS sending code 36 but stayed clear when the maf relays were replaced.
The repair book says if you remove the maf it should run rich but it stays lean.
I'm not the mechanic, so this info is a little wanting I know, sorry. dyno don is workin on this for me but he's never seen this before and is pullin his hair out too, and no one knows that we've talked to so far.
If you think you've seen this before or know of a solution but need more info please email me or post here so I can get the info. Any help greatly appreciated!
Old Jun 29, 2002 | 05:29 AM
bump
Old Jun 30, 2002 | 03:26 AM
please see this thread instead
https://www.thirdgen.org/techbb2/sho...hreadid=116298
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
