2.8 to L03
Old Jun 29, 2002 | 06:55 AM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
2.8 to L03
Hey guys, I was wondering if you could answer a few questions on swapping a 2.8 to an L03....
Will the fuel pump be sufficient or do I need a new one?
Will the driveshaft bolt up, and is it the same as the v8 driveshafts?
And one off subject question, how hard is it really to swap from an auto to a manual tranny,?
The part about that I'm most worried about is clutch pedal/master cylinder installaion, are there dimples in the metal where they would go?
Old Jun 29, 2002 | 07:20 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I can't help you with engine swap but check out Technical Articals on the home page. Look under transmission and you will find a very good and complete artical on the swap from auto to manual trans.
Old Jun 29, 2002 | 07:44 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the fuel pump will work with a 3 port AFPR, I used a Malory. If you keep the auto, you will need one from a v-8. If the original and new are 700r4's, the driveshaft will bolt on with no mods.
Do a search on the topic, plenty of info here.
Old Jun 29, 2002 | 08:04 AM
how much fuel pressure does the tbi need?
Old Jun 29, 2002 | 09:10 AM
Engine: 406
thought you were going carb...cant help ya with the TBI questions. Scratch the 3-port. Try posting on the TBI board.
Old Jun 29, 2002 | 10:21 AM
Slade1's Avatar
A TBI needs around 12-15 PSI from the pump. A TPI needs 45-50 PSI fromthe pump. A Carb needs a whopping 6 PSI from the pump. So in my opinion a TPI pump with a AFPR is the best way to go so that way you can go whatever route you need or want for an engine.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
anesthes
Sep 21, 2015 10:24 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
