Starter Grinding but not turning engine Over???
Old Jun 29, 2002 | 11:57 AM
maksik7's Avatar
Just like the title says, I turn the key the starter gear pops out, engages with the flywheel but can't turn the flywheel and just makes a clicking noise from the starter. What could be causing this? A bad battery or something else? Thanks for the help.
-Max
Old Jun 29, 2002 | 01:41 PM
ede's Avatar
ede
low battery or a bad starter. you ought to trouble shoot it a little more and see what your battery has and what's getting to the starter.
Old Jun 29, 2002 | 08:17 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Your question needs a little clarification---
is the starter actually engaging and not turning the motor
or is it not engaging the ring gear fully and grinding against the edge
both cases you should get a new starter (they are cheap) but the fix is different.
if the starter engages then doesnt have the juice to turn the motor check the wiring and the timing (too much advance can cause this)
if the starter was grinding you need to shim the starter correctly as this was not done with your current starter and thats why it grinds. if you have had this problem for long enough you can actually grind some of the ring gear off in which case youll need a new flywheel/flexplate because the old one will be unbalanced.
good luck
James
Old Jun 29, 2002 | 09:23 PM
1982chevycamaroz28's Avatar
its ur starter. i had the same problem last yr with mine. just get a good replacement one and also get ur battery fully charged. becuz after we replaced the starter on my car it never made that noise again.
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
