305pti running bad
Old Jul 1, 2002 | 06:23 PM
85_iroc305tpi's Avatar
305pti running bad
My 85 iroc 305 tpi started running awful. So I did the normal tune up. Cap,rotor,wires and plugs and o2sensor and changed the oil and filter. Car was still running awful so I bypassed the est and set the timming to 6btdc . Still no change . So I changed the fuel filter and pvc. Checked all injectors and their all at 11 - 13.
Any suggetions would be appreciated !!
Old Jul 1, 2002 | 07:40 PM
ede's Avatar
ede
do compression test, check vacumn, check FP and volumn
Old Jul 1, 2002 | 07:56 PM
I'll test fuel pressure and volume 2marrow.
for the vacum I insepted all the lines and they all seem fine .
Is there another to test for vacum..
Old Jul 4, 2002 | 02:47 AM
orod's Avatar
Car: 86 Z-28
having similar problems and hope for more feedback....
Old Jul 4, 2002 | 08:41 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
I thought the same thing it could be somthing the same,check your timing,but now I might need a new engine.
Old Jul 8, 2002 | 10:52 PM
Finally had time to work on car. found loose wires going into the fuel pump relay. (repaired them ) Still no help .
Fuel pressure 44psi sprayed water around vacum lines and intake no bogging
rechecked the gap on plugs all .035
all injectors getting power and resistance 16.6 on all.
rechecked timming 6dbtdc in by pass around 14db with est connected.
had ignition module tested its o.k.
any other ideas ????
1985 305tpi 127,000
all stock for now.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
