Head gaskets
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
Head gaskets
I will be swapping in new heads very shortly. My problem is this. I purchase Dart Pro1 heads with 72cc combustion chambers, the biggest they had. I want to decrease my compression ratio to under 9.0:1 because I will be running a procharger. Can I have a machine shop port out the chambers or are there thicker head gaskets available that will reduce compression ratio? Anyone have a calculater or gasket thickness to get ratio to desired amount? It is a stock 5.7L in a 1988 GTA.
Car: 4
Engine: 6
Transmission: 5
Actually, the Fel-Pro 1044 is about .010" thicker...
but with the L98 short block, 72cc heads should give you about 8.8:1 or thereabouts, with the regular .041" gasket.
Engine: Blown 355
8.8:1 sounds good to me. I was told the L-98 came stock with 74cc heads and 9.3:1 compression?
Engine: Blown 355
Thanks five seven maybe they did say 64 and I heard 74.:hail:
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
