Can I change this...
Old Jul 4, 2002 | 12:51 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
My mechanic installed new chrome valve covers for me when he changed my gaskets. On the pass. side is a small breather element withy holes in the bottom of it. When I drive the car I get smoke from these holes whenever I stop.
Question: Can I change this to just a plain oil cap?
The drivers side has my PCV in it. I have a LG4 with carb.
Old Jul 4, 2002 | 03:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the reason u see smoke is because of the blowby past rings, valve guides, etc. All engines have soem blowby. When the car stops, the pcv shuts to allow the engine to idle and hence it stops taking up the fumes in the crank case. Leave the breather there.
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
