a/c and idling?
Old Jul 4, 2002 | 05:01 PM
lanespice's Avatar
a/c and idling?
when i start the car while engine is still cold and the a/c is off ..it starts right up but then the a/c pulley activates after a minute then the car begins to idle up and down..does that for a minute then the pulley stops and the up and down idling stop but as the car heats up the idling up and down thing stop but the pulley continues to go off and on it never stops but when i turn the a/c on the pulley stays on..whats going on here???
Old Jul 4, 2002 | 05:26 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Uhh...ok, so what you're saying is, the a/c is turning on and off by itself at times; but, when you put the selector lever on an a/c position, the a/c comes on and acts like it's supposed to?
As for the idle, it's supossed to idle up a little when the compressor kicks on.
Old Jul 4, 2002 | 05:53 PM
lanespice's Avatar
no even when the ac is off the pulley turns on then off then on then off it continues the same pattern off then on
Old Jul 5, 2002 | 11:25 AM
Vader's Avatar
Either your AC clutch idler bearing is locking up or the HVAC coneols are cycling the compressor on and off. Remove the electrical connector from the clutch to see if the phenomenon still occurs.
Old Jul 5, 2002 | 11:51 AM
lanespice's Avatar
already tried pulling the conecter off and the clutch does quit cycling but the idling up and down continues
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
IROCtometal
Sep 2, 2015 02:01 PM
