Spedo
Old Jul 4, 2002 | 11:30 PM
dpav's Avatar
Spedo
I have an 86 z28 and I have stock rims on, however I got a set of 16 inch iroc, but, do I need to calibrate my spedo for them? its a 115.
Old Jul 5, 2002 | 12:33 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
As long as the tires are the same height or diameter. Like if you go up in wheel size but with a lower aspect ratio you can get it close enough to not notice it. For example I'm not sure what the stock 15" size is but if you go from that to the stock 245/50-16 you should be ok. I would lay a ruler on the tread (like you're measuring the width of the tire) then just measure from the center of the wheel to the ruler on your 15's then on the 16's. If you do find out you'll be way off then you'll have to change the speedo drive gears in the tranny. There's an article in the tech section here on how to do that. If I've confused you just let me know.
Old Jul 5, 2002 | 01:28 PM
dpav's Avatar
You didn't confuse me, I understand, I appericate the help. I got my camaro in the winter, and we just are almost done restoring it now...so, I'm new to this car stuff.
Old Jul 5, 2002 | 06:01 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Cool, congrats on the car! I would love to see some pics and hear some more about it. Send me an email if you want. jasonb4z@hotmail.com
Take it easy,
Jason
Old Jul 6, 2002 | 01:57 AM
KiLLJ0Y
Guest
Posts: n/a
the only time you ever really need to recalibrate for new bigger wheel size is anything over 17"... the margin of error is soo few.(as long as you are staying with some "normal" size tires) which means no big giant slicks...
dont worry.. your speedo is fine
grngryoutmyway
Nov 15, 2003 09:33 PM
Gumby
Oct 5, 2003 03:01 PM
87cam305
Aug 18, 2003 03:49 PM
94'_SS
May 24, 2002 07:12 PM
