how good are plastic rhino ramps?
Old Jul 5, 2002 | 12:40 PM
Tas's Avatar
Tas
some guy just told me they crack. How safe are they?
Old Jul 5, 2002 | 01:08 PM
85_iroc305tpi's Avatar
I use them all the time and so far no problems.
I'd also go ahead and use a floor jack or jack stands if your nervous.
Old Jul 5, 2002 | 01:11 PM
Tas's Avatar
Tas
I'd like the ramps because the jacks and stands make me nervous as hell on this damn unibody car. With my Jeep, jacks and stands are no sweat.
Old Jul 5, 2002 | 01:37 PM
Cole's Avatar
I've had mine for about 1-2 years now and use them all the time. I haven't seen any signs of wear or cracking.
Old Jul 5, 2002 | 02:57 PM
breathment's Avatar
my only problem with them.. and i don't think they are rhino ramps. just some ones one got at autozone.. but they don't grip the ground to well when i'm trying to get up on them. they sometimes slide forward.. but it might just be the crappy ground out here with rocks on it. that any my rear brakes not doing their job.. but other then that, the ramps are awsome..
Old Jul 5, 2002 | 10:23 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
There was a thread about them on corvetteforum last year and many people loved them. The only complaint I remember is that if you leave the car up on those ramps for a week or two they start to warp a little.
Old Jul 5, 2002 | 11:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i have used the ramps and yes, they will slide if your not careful. I personally jsut slip some stands under the axle tubes and front control arms to avoid damage to the sub frame rails.
Old Jul 5, 2002 | 11:39 PM
breathment's Avatar
i want to put the stands under the rear axle tubes.. but the brake lines are in the way (on the bottom).. are urs like that too??
Old Jul 6, 2002 | 11:15 AM
Car: 88 Camaro SC
Engine: SFI'd 350
i think the e- cable rund there for a bit... cant remember. i just put the stands in between the space whre the lower control arms bolt up to the axle and the wheels. That seems to work
Caspar
Jun 19, 2016 11:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
MORREALE5
Sep 13, 2015 09:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
