How exactly does EGR work?
Old Jul 6, 2002 | 10:43 PM
Tas's Avatar
Tas
at certain times it pulls exaust gas from the exaust crossover in the heads and puts it in the intake, right?
Old Jul 7, 2002 | 05:41 AM
ede's Avatar
ede
yep that's how it works, controlled by vacumn and a senser now, the first ones were just vacumn controlled
Old Jul 7, 2002 | 08:11 AM
ronterry's Avatar
Car: '94 Corvette
Reduces your NOx buy reducing your combustion temperatures. It also reduces your MPG requiring you to burn more fuel, and expel more gases… hmmm EPA hmmm
Ron
Old Jul 7, 2002 | 11:43 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The Lowdown on Code 32 (EGR)
http://sethirdgen.org/egr.htm
1985-1989 V8:
http://sethirdgen.org/egrii.htm
Old Jul 7, 2002 | 07:06 PM
Jza's Avatar
Jza
Welllll, actually, to be nitpicky, it's controlled by the ECM through the EGR solenoid, which meters the vacuum controlling the valve. On TPI cars, MAF vehicles also had a temp switch installed in the EGR valve that allowed the ECM to determine if the EGR valve is functioning properly. Later SD (TBIs are SD, too) cars got rid of that switch because the computer was now smart enough to figure it out on its own. No real "sensor" involved.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
camaroken83
Aug 10, 2015 11:35 AM
drathaar907
Aug 6, 2015 04:20 PM
