Proform Shift Light Question
Old Jul 7, 2002 | 06:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I am thinking of purchasing proform adujustable shift light, and was wondering about the wiring of it. I know it is going to require me to hook it up to the tach wire on my distributor. I want to retain my stock tach and this light at the same time; so can I run my stock tach wire and the shift light wire together into my distributor? Will both still run correctly? It is possible to have this hooked up and my stock tach hooked up at the same time isnt it?
Here are some links:
http://www.proformparts.com/parts/67005C.html
http://www.jegs.com/cgi-bin/ncommerc...72&prmenbr=361
Brady
1992 Camaro with holley carb and accel HEI distributor
Old Jul 7, 2002 | 07:49 PM
ede's Avatar
ede
should be no problem at all. if i were you i'd consider a shift light that took the pills, like msd.
Old Jul 7, 2002 | 07:55 PM
Marshall89ws6's Avatar
i have this light but i have msd ignition and the msd box has its own tach drive so i ran the light to that instead...... u can run them both to the dist but i dont know how...
Old Jul 7, 2002 | 09:51 PM
Basically the question is it okay to have two tach input wires on one output?
Old Jul 8, 2002 | 10:24 AM
ttt
Old Jul 8, 2002 | 10:56 AM
NTChrist's Avatar
Yeah, I'd like this one answered too. I'm considering buying the same light.
As far as I can tell from your setup, Brody, you must be trying to copy me! We have pretty similar cars. Or at least we will when I'm done all my work.
Any ideas on what yours runs?
Old Jul 8, 2002 | 12:29 PM
nawww i think you are copying me. i ordered the light sunday night so we will see by saturday if it works out. i estimate mid high 14s in the quarter although there are no tracks near me, yet. they are halfway done building a 1/8th mile track so i guess i will have some times in a couple months.
Old Jul 8, 2002 | 09:03 PM
https://www.thirdgen.org/techbb2/sho...965#post756965
Old Jul 8, 2002 | 10:05 PM
NTChrist's Avatar
Not too sure what the gobbledy-gook is, but I understand that the two wires can work off of one signal. I'm happy.
Thanks Brody.
Old Jul 8, 2002 | 10:21 PM
i dont really understand that either. i will just splice it right before the distributor where i know i will be getting the right wire.
Old Jul 8, 2002 | 11:18 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yeah, I did this with an AutoMeter shift-lite. Just splice in to the wire coming off of the 'tach' post on the distributor. On a stock HEI, I believe it's the rear one.. it is marked in any case. Green wire, i think. The signal comes from the distrubutor, not the tach, so you can splice in anywhere between the two. It's a pain in the butt with a TPI cause there's no room, but I see you have a carb, so it should be easier. Less than an hour, start to finish.
Old Jul 9, 2002 | 07:53 AM
thanks
Old Jul 9, 2002 | 12:51 PM
Desert86Roc's Avatar
Yes, it works just fine. I have the same Proform light. However, a buddy of mine had to have 3 of them shipped to him before he got one that worked. They are definately cheap, but still work.
Instead of splicing the wires, I just made a small "y-harness" where I used a several of the blade style connectors a short piece of wire and kept my stock harness intact.
I like the fact that I can "dial" the rpm I want, and not depend on having the correct "pill" like the MSD. And no matter what one you get, it will help your consistency.
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
