timing light instructions needed
Old Jul 7, 2002 | 07:18 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
I need help using this timing light. It is not the dial kind. It just has 2 alligator type clips(red and black). And it has one that says spark plug with an arrow. I guess you put this on the #1 spark plug, but which way should the arrow face? Also, what do I connect the red&black clips too? Any other information on using the light would be greatly appreciated, as this is my first time using one.
Thanks,
brett
Old Jul 7, 2002 | 07:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Shouldn't matter which way the arrow faces (that I know of), just put it on the plug wire. And the other goes to the battery terminals.
Old Jul 7, 2002 | 07:27 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Mark,-or anyone
It goes on the plug wire, or the plug itself??
I am a little confused as to how it works by just putting it on the wire.
thanks,
brett
Old Jul 7, 2002 | 07:33 PM
Car: 99 Formula
Axle/Gears: 342
It goes on just the wire. Electricity still conducts through the wire.
Old Jul 7, 2002 | 07:44 PM
ede's Avatar
ede
the arrow on the clip should be on the plug side of the #1 plug wire and the red wire to the + and the black to the - sides of the battery.
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
cool,
so I still hook up the wire to the plug. Makes a little more sense now.
Is there any way to tell if the engine "WANTS" to be advanced more. For example what kind of sound will it be making (if any) if it wanted to be advanced more, or was advanced too much, etc.
Thanks for the help.
Brett
Old Jul 7, 2002 | 07:49 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
for best performance, play aorund with it a little
advance it until it pings, then back off some.........
Old Jul 7, 2002 | 07:55 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
cool, thanks,
one last thing(hopefully).
vacuum advance line is unplugged from dist. and plugged right?
And, if you know off hand, which way do you turn the dist. to advance?(clockwise or counter?)
I can just check once I start if you aren't sure, but thought I would ask since I am posting anyway.
Thanks again
Old Jul 8, 2002 | 05:18 AM
ede's Avatar
ede
some people set it to reach max vacumn readings. i'd set it till i got knock, or knock counts on the scanner then back it off 2 or so
Old Jul 8, 2002 | 01:47 PM
rezinn's Avatar
I feel like saying turn it clockwise to advance, but I'm not sure about that. Just hook up the light and spin it a little bit to get a reading, then you'll know for sure.
Old Jul 8, 2002 | 02:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i beleive its turned counter clockwise to advance
Old Jul 8, 2002 | 06:26 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
counter clockwise it is
Old Jul 8, 2002 | 06:43 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
thanks everyone
much abliged
IROCZ1989
Jan 24, 2016 03:55 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
