cam break in
Old Jul 10, 2002 | 09:11 PM
cdogc350's Avatar
cam break in
Im gonna install a new cam in my small block....can someone who knows well about it give me the procedure on breaking the cam in
when adjusting a hydraulic lifter i beleive you tighten the rocker till there no more space between the valve tip and the rocker tip? correct?
Old Jul 10, 2002 | 09:32 PM
rhuarc30's Avatar
Well it's a little more complicated than that Check out this link
http://www.darklair.com/monte/howto/...lve_lash.html. Once that's done start the car, set the timing quickly, then bring the rev's up to somewhere between 2500-3000 and let it run for around 20 minutes. Now if it's a roller cam, don't worry about it, theoretically roller cams don't need a break in period, though I usually still do it just to be on the safe side.
Old Jul 11, 2002 | 05:36 AM
ede's Avatar
ede
use a lot of moly on the cam lobes, i'd fill it with 30w oil and change it after 30-60 miutes.
Jorlain
Oct 8, 2015 01:57 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
