? about cam specs
Old Jul 14, 2002 | 12:15 AM
MrsLottaBallsCamaro's Avatar
? about cam specs
The advertised lift of a cam is at the valves right? So that would include the 1.5 rocker multiplication? so a 525 lift cam would achually put out 595 lift with 1.6 rockers?
Old Jul 14, 2002 | 12:23 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
No those numbers are at the lobe.
Not every engine has rocker arms with the same ratio.
and if you take the distortion of the valvetrain geometry into account then those numbers could vary way too much.
Old Jul 14, 2002 | 05:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, cam spec lift is given at the valve. However your arithmetic is a bit optimistic: .525" divided by 1.5 gives .350" lobe lift, which will give .560" at the valve with 1.6 ratio rockers.
Old Jul 14, 2002 | 06:05 AM
ede's Avatar
ede
Old Jul 14, 2002 | 01:50 PM
This is too much math for me I barely passed geometry in high school
Old Jul 14, 2002 | 09:46 PM
NTChrist's Avatar
RB83L69 is correct. Usually the cam manufacturer used the stock ratio for computing the valve lift.
If you want to find the lift of a cam with a non-stock rocker arm ratio, you first divide by the stock ratio (to find the lobe lift), then multiply by the non-stock rocker arm ratio. 2 easy steps.
Old Jul 14, 2002 | 10:41 PM
Car: '86 Trans Am
are you serious?
Most factory rocker arms don't even have even or exact rocker arm ratios, like on my friends 390 ford shortblock I built for him last summer it was supposed to be 1.48 rockers but they measured out to a 1.41 ratio except for two or them.
and beside do all small block Gen1 engine have 1.5 rocker arms.
Dammn those cam people.
Old Jul 14, 2002 | 11:21 PM
Guest
Guest
Posts: n/a
LOL!
Well you almost topped my lousy subtraction of peanut cam lift and 'better' cam lift... almost. I think from now on I had better use a calculator rather than my head for simple math
Almost all cam manufacturers list the valve lift with some 'standard' rocker arm ratio like for Chevy cams they use 1.5 as the ratio. It is easier really, most of the time you know what valve lift you want but not what lobe lift. I'd have to take a number and divide it by 1.5 (or 1.6) and then I could tell you what lobe lift I'd be looking for.
RB is right about the number.
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
