Rear Main Seal Bolts
Old Jul 16, 2002 | 12:18 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I recently got my 3rd gen and I was just changing my oil and noticed a leak around my rear main seal, I then noticed that 3 of the bolts that hold the 2 peices around the seal together are missing! Can anyone tell me what size these are so I can get new ones? BTW its a 5spd. Also will I need to put a whole new seal in or will just putting in all the bolts fix the leak?
Old Jul 16, 2002 | 12:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
um... uh.... you sure you know what you're looking at? I'm not super familiar with 1-piece blocks but I don't think there's ANYTHING visible back there. All of the bolts for the RMS should be covered by the oil pan. Does a 1 piece even have bolts? Isn't it just pressed into the block? I thought that was the whole point to the 1 piece?
Old Jul 16, 2002 | 12:58 PM
ede's Avatar
ede
i think you're both confused. the piece that hold the rear main seal in is one piece on all the gm engines i've worked on. if i recall correctly there is one nut and 3 bolts, 5 or 6mm i think. i'd go to a gm parts dealer and order what i needed from them. you wouldn't of been able to see the rear main seal or it's houseing by changing the oil, you'd need to drop the trans.
Old Jul 16, 2002 | 12:59 PM
Car: 1986 IROC-Z28
I'm not too familiar with cars altogether BUT ok I will try to explain it. The bolts hold together 2 pieces that are on the back of the block, Like near the front of the bellhousing, Around the clutch or something around there I would assume. And it is leaking oil. Any ideas?
Old Jul 16, 2002 | 01:09 PM
ede's Avatar
ede
i doubt what you're look at is the main seal, i also doubt if what you see is leaking. i'll bet the leak is somewhere else and dripping where you're looking. sorry but i can't quite figure out what it is you're looking at. maybe the sheet metal shield for the flywheel.
Old Jul 16, 2002 | 01:12 PM
Car: 1986 IROC-Z28
YES! That sounds right! It's very think metal and bolts onto the bellhousing. What else would be leaking though? The entire tranny is coated in oil. Any ideas?
Old Jul 16, 2002 | 06:58 PM
ede's Avatar
ede
could be the front seal of the trans ,oil sender, valve covers, just about anything.
Old Jul 16, 2002 | 08:19 PM
Hulk0202's Avatar
Wipe it all off and try to find it after running it a while.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
