Are my lifters bad??
Old Jul 19, 2002 | 02:05 PM
wh0di's Avatar
Ok after reassembling my engine, I reused my roller lifters with my new LT4 cam.
Im in the garage trying to get the valve lash and here is what happens on some of the rocker arms.
I'll keep tightening them, but they still wiggle (the rocker arms). and the adjusting nuts are way too far down compared to the good valves. With the engine running, I'll get them to stop clicking, then like 10 seconds later they'll click again ...
Whats the deal?? Is there any way to solve this besides pulling the intake and getting $400 lifters?
Old Jul 19, 2002 | 02:18 PM
ede's Avatar
ede
you don't tighten till they stop wiggling. engine off, valve closed tighten till the push rod stops spinnning, make sure the lifter doesn't start on flat cams then tighten 1/2 turn more. engine running loosen till it ticks then tighten till it stops then 1/2 turn more
tyeo098
Nov 30, 2015 06:27 PM
RyanJB
Sep 14, 2015 03:39 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
