So you're looking at a 3rd gen for sale...
Old Jul 21, 2002 | 01:15 PM
Conv389drv's Avatar
You go to check out a "for sale" ad on a Firebird. You look inside the car and see an automatic shifter. You look under the hood and see Tuned port injection. You think to yourself, this could be an L98 car; but the option code sheet is missing. Sooo, how can you tell whether this is a tpi 350 or just a 305?
Old Jul 21, 2002 | 01:50 PM
jd13's Avatar
The 8th character in the VIN on the dash. If it's an 8, then it's an l98 (350).
Old Jul 21, 2002 | 02:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, assuming it's the orginal engine.
Old Jul 21, 2002 | 02:44 PM
ede's Avatar
ede
best to get casting number off the engine
Old Jul 21, 2002 | 02:58 PM
Conv389drv's Avatar
Okay, so if I get the casting number, where can I look up information about it? Is there an engine ID book or website?
Old Jul 21, 2002 | 02:59 PM
Enkil's Avatar
www.mortec.com
Old Jul 21, 2002 | 03:09 PM
jfox55's Avatar
where is the number at on the engine????
Old Jul 21, 2002 | 06:28 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
behind the driver side cylinder head, on the block. wires can be in the way, and it could be a pita, but that is one of the places, there are a couple more
Old Jul 21, 2002 | 07:19 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Or, scrape the gunk off the passenger side head, just behind the water pump. There is a small pad there where the last digits of the VIN number are stamped (vehicle sequence number). Those numbers should match the last ones on the VIN if it is the original motor. And like the others said, 8 in the VIN.
Old Jul 21, 2002 | 07:48 PM
Conv389drv's Avatar
Thanks guys, I appreciate it.
Old Jul 21, 2002 | 08:14 PM
igotslicksNchix's Avatar
i'm pretty sure mine says TPI 5.0 on the intake
Old Jul 21, 2002 | 08:41 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
and do we realize how easily emblems can be changed
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
