high idle wont kick down
Subscribe
Jul 23, 2002 | 11:12 AM
no luck with this on the carb board....
i have a holley 4160, when i first start it in the morning it idles at 2000 and i have to goose the throttle to kick it down to 1200. after the car is warm and i accelerate past 1500 rpm while driving the engine speed wont go below 1500 again unless i goose the throttle and then it'll drop to 750. i want to idle at 1200 cold and 750 hot, what to do? the carb has an electric choke, if it makes a difference.
Reply 0
Jul 23, 2002 | 01:59 PM
This REALLY belongs in the carburator forum.
The reason it's doig is that is because you have your idle screw set way too high. I'd say, back off about 1 and a half turns and then mess with the mixture screws on the side of the bowl.
Reply 0
Jul 23, 2002 | 03:24 PM
i know, but i didn't get any responses on the carb board, not enough traffic
i thought the fast idle speed screw only controlled the fast idle speed and didn't control whether the fast idle was on or off?
Reply 0
Jul 23, 2002 | 04:21 PM
sounds like your electric choke needs to be adjusted...
Reply 0
Jul 23, 2002 | 05:22 PM
can you give specifics? i have the choke set so it has just enough preload to shut all the way with the engine cold.
Reply 0
Jul 23, 2002 | 07:47 PM
Check the linkages and lube them as necessary.
Make sure the choke is actually drawing power to verify if the elec heater coil inside is working.
Reply 0
Jul 23, 2002 | 08:30 PM
this happened to me once. check the throttle return spring sometimes if it gets streched it doesn't spring back together and it will keep the idle up.
Reply 0
Jul 23, 2002 | 10:29 PM
i think i may have fixed it. i removed the choke housing and saw taht the fast idle cam developed burrs on it since it's plastic so i think it may have been getting hooked on the fast idle screw so i cut the burrs off, backed off teh fast idle screw and leaned out my choke a bit, i'll see what it's like in the morning after sitting all night. thanks for your help guys
Reply 0
Jul 24, 2002 | 03:06 AM
Well I'm not talking about the fast idle screw, but the main (driver's side right unde the linkage) idle screw.
Reply 0
Jul 24, 2002 | 07:58 AM
U-Train,
You need to get your hands on a maul. Not one of those little wood-splitting types, but a big old fat-*** railroad spike maul. Open the hood, remove your favorite air cleaner, and take your best Sammy Sosa-esque swing at that die casting that reads "Holley" on the front.
Either than, or get a replacement high idle cam, since the replacements are likely metal, not plastic.
Reply 0
Jul 29, 2002 | 09:59 PM
thanks guys, and Vader, I'm just milking this carb til i get the lt1 intake on which is pretty soon i hope. turns out the problem was the throttle return spring wasn't pulling hard enough so i just rebent it so it's shorter and problem solved.
Reply 0
Subscribe
