454 tall
Old Jul 23, 2002 | 04:49 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
454 tall
i have a freind that has a 454 tall block brand new never used hell sell me for 75 bucks, my question w/some modding on the frame can an 89 t-top support it, and also will it fit if i did?
Old Jul 23, 2002 | 05:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: 454 tall
I've heard of a short and long block, but never a tall block.
Only $75, I'd buy it even if it doesn't fit. You'll need suspension upgrades including some SFCs.
Old Jul 23, 2002 | 05:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I didn't know there was a 454 tall block, only 427 and 366 ones... what year is it from?
Ssince the deck is .400" taller on each side, that means the heads are about ¼" farther apart and about ¼" higher... seems like that would just add a little extra squeeze to the header and hood clearance issue.
But it might go, be brave, be the first to try and let the rest of us know how it fits.
Old Jul 23, 2002 | 05:59 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Buy it, sell it to a hardcore racer for double, then go get a short deck block, then all the info you need is on my page at www.koolmeister.com
Miles
Old Jul 23, 2002 | 07:43 PM
boogie's Avatar
Never heard of a 454 tall block. 427 and 366 tall deck blocks were used in 2 ton trucks. I would pass on installing it in a thirdgen.
Lonnie
Old Jul 23, 2002 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No such thing as a factory tall deck 454. It's probably a 427. The 427 tall deck block is the same bore as a 454 but a shorter stroke. You can put the 454 crank into the 427 block and "make" a 454 tall deck. The 427 block can be bored out .125". Installing a stroker crank you can easily make a 496.
The reason the 366 and 427 truck blocks are tall deck is that the pistons have an extra compression ring. This make the cylinder requirements to be .400" longer.
As for installing it into a third gen I'd also suggest getting a short deck block. If you plan on keeping stuff under the hood such as a wiper motor and heater/AC then a tall deck block will probably cause a lot of interferance problems.
You can buy a 4.5" bore short deck block, throw a stroker crank into it and make a 540.
Tall deck blocks can be a pain. Regular intake manifolds won't fit without special spacers. A longer oil pump drive shaft is required. Longer pushrods are required. Everything needed for the extra .400" height. Using headers may not work since the exhaust ports are in a different position compared to a short deck block. Hooker Supercomps are hard enough to install on a short deck block.
Old Apr 24, 2011 | 09:54 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: 454 tall
They do have tall deck 454's i have 1. alot of the tall blocks were used in the boats and came with steel cranks and 4bolt mains.
http://racejunk.com/articles/article-4.html
Old Apr 27, 2011 | 08:47 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: 454 tall
and they also have oval ports. there were none made in factory vehicles but some rv's and other heavy vehicles had them. but mostly in boats
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Numbah-1
Sep 12, 2015 08:57 PM
IROCZ1989
Sep 4, 2015 11:54 AM
cRoe4
Aug 7, 2015 08:46 PM
