tires hop
Old Jul 25, 2002 | 06:31 PM
uidzer0_z28's Avatar
tires hop
Hey everyone,
When I do a burnout my rear tires hop up and down a little.. Is this normal in our cars or is there somthing I have to do to fix it?
Thanks,
Ben
Old Jul 25, 2002 | 07:20 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
It is normal if it is not Posi. It is something that can be fixed. The best thing would probably be new LCA's with Relocation Brackets.
Old Jul 25, 2002 | 11:28 PM
any one know if the 82 z28 came w/ posi or not? Just want to make sure mine is not shot or somthing.
thanks,
Ben
Old Jul 25, 2002 | 11:34 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
thanks,
Ben
All third gens 82-92 had the posi as an option mine came FACTORY (as in on the build sheet) with 3.73 posi / 4 speed
ALSO LCA relocation brackets make all the difference in the world!!!
Old Jul 26, 2002 | 02:06 PM
iroc22's Avatar
The RPO code for posi was G80. B2L and G92 had the posi included in the package. Since yours is an 82, you would have to find the build sheet for you car.
Old Jul 26, 2002 | 03:12 PM
BumpaD82's Avatar
Good point look for your build sheet, mine was under the drivers sheet stapled to the foam.. build in Van Nuys...
Old Jul 27, 2002 | 01:05 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
It should be in the console, taped to the inside.
I think a posi was standard equipment on a Z28, though I may be wrong.
Old Jul 27, 2002 | 02:36 PM
I think the last owner ripped it out, any way I am going to try to restore the sticker on the inside of the door, it is painted over.
I would think the z28 came w/ it though
how much are LCA relocation brackets ?
thanks,
Ben
Old Jul 27, 2002 | 04:46 PM
iroc22's Avatar
Posi wasnt standard til '90 and that was with the IROC's and Z28's following that.
Are you referring to the SPID sticker in the console? cause that came out in 1985 IIRC.
Old Jul 27, 2002 | 05:24 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok now I wish I could figure out my wheel hop
I don´t have a LSD
but I do have IRS, and something that makes the rear wheels toe in on accel
and my susp is getting weak with 175k miles on the ticker
Old Jul 27, 2002 | 06:31 PM
Is there a way to add POSI without getting a new rearend?
-Ben
Old Jul 27, 2002 | 07:27 PM
jeffs82z28's Avatar
Lincoln Lockers only cost a 12 pack of beer
If you want posi, at minimum, you will need a posi carrier.
Eaton sells one for about 450 bucks.
Or, you may be able to find a stock piece for about 100.
Old Jul 28, 2002 | 01:14 AM
Rob454's Avatar
Hi guys
im new here.
i hada 89 RS with a 305 that had wheel hop. one thing that got rid of a lot of it was adding new rear shocks and polyurethane pieces for the traction arm that runs along the driveshaft. later on I had a buddy of mine who is a welder box in the arm
Rob
Old Jul 28, 2002 | 04:32 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
my 89 RS rear end hops like mad. adding new shocks / struts / springs all around fixed it.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
