Help! High Beams Won't Turn Off!
Old Jul 26, 2002 | 08:53 PM
Ratstix's Avatar
whenever i pull the handle back it wont click for the highs to go off.
what can i do to fix this?
Old Jul 26, 2002 | 08:56 PM
Ratstix's Avatar
nevermind. i just went and started it up again it they click off correctly.
why did it do this?
Old Jul 26, 2002 | 09:17 PM
ronterry's Avatar
Car: '94 Corvette
There should be a little clicker switch down on the driver side of the steering column, above where your feet are. There's a metal rod that runs from the turn signal/high beam hangle to it.
Check the swith itself, or the rod might be getting hung up on something. It also could be the bracket the mounts the turn signal/high bean handle to the rod. (I think theres a bracket there?)
Ron
Old Jul 27, 2002 | 05:32 AM
ede's Avatar
ede
if you change the switch, i've neve done oen i na camaro, it should be 2 screws and a harness. pretty easy to change, and cheap. tape the rod to the stearing column before you start so the rod doesn't move off the handle.
Old Aug 1, 2002 | 08:40 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Are you sure it is the switch that isnt working? I had a prob like that that I traced to the fog light relay and the way that GM wired it up. Look at a wiring diagram sometime and you will see what I mean. But what you are describing sounds like what mine was doing... low works fine, switches into high fine, but wont switch back to low unless you turn off the lights and turn them back on again.
Old Aug 1, 2002 | 09:30 PM
BOTTLEDZ28's Avatar
Transmission: A4
If it happens again, try tilting the wheel in diffrent positions and click the high beams. Sometimes my high beams wont work unless i put the tilt up first. i know its loose screws near the pedal. just havent gotten around to tighteningh them yet yet
Old Aug 1, 2002 | 10:49 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
mine used to do that too. the way i fixed it was, i had the tilt sterring down to low. it wont click it off if its to low.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BrianI
Aug 9, 2015 11:52 AM
