O2 sensor problem
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
O2 sensor problem
This is for all you EFI guys out there, sorry it's so long. I have edelbrock's EFI, and about a week ago I noticed it was really sucking up gas, I was looking at the control pad and the O2 sensor light was red -lean condition I thought that was wierd so I made the mixture as rich as it would go (to the point where black puffs were coming out the exaust) and guess what still red so I assumed bad O2 sensor so I go to autozone and get a new one, but while trying to install it i figure out it has the wrong plug, so I left the old one disconnected and go back and get the right one but I noticed that the light was flashing green(rich) and red on the way there and back WTF??? anyways I install the good one and same problem the edelbrock manuel says that the light is dark and I should get a error message with the sensor disconnected what the HE!! is going on I'm working 12's so I can't call edelbrock tech support and the car is currently locked out of closed loop. when I get time I plan on borrowing one of the shop's fluke DMM's (hope MSgt XXXXX dosen't catch me) and checking between the pin for the O2 sensor and ground and seeind if I get any reading otherwise I'm stumped any other Ideas???:hail: :hail: :hail:
92camaroJoe
Aug 13, 2015 06:07 AM
