engine picking
Old Jul 31, 2002 | 09:26 PM
cdogc350's Avatar
engine picking
Im pulling my motor to do some engine bay ad motor freshening. i went through all the trouble today of disconnecting the tranny and getting the motor ready to be pulled only to find that my cherry picker cant reach safely above the motor. It reaches about where the fan meets the pully. It looks as if it wont reach because ive got the car on ramps. Now i cant take the car off the ramps because of the tranny and other things being held underneath by jacks and what not. I was thinking my only other option would be to take the front clip off. anyone got any ideas so i dont have to remove the clip..if not....could you quickly run throught the removal of the clip....ive never done it before
Thanks...
Old Aug 1, 2002 | 10:42 AM
Vader's Avatar
As I see it, the easiest options would be to either remove the jacks and lower the car, or get a taller picker or chainfall attached to a gantry or solid beam in the garage (the standard ceiling joist or bottom cord on a truss doesn't qualify for the latter). Removing the front end sheet metal is going to be a lot more unnecessary work. It would be easier to disassemble the engine in the car and lift out only the short block if necessary than to remove the sheet metal.
Old Aug 1, 2002 | 12:09 PM
1986redbird's Avatar
this may sound obvious but, the boom on the engine lift slides out to extend the reach of the hoist, when I pulled my motor to replace it I had the car on blocks and bricks (with jackstands too) and had no problem reaching the lift area. I also had to extend the boom to reach the engine. may be worth a look.
Old Aug 1, 2002 | 01:10 PM
urbman's Avatar
You could drop the k member and "lift" the front of the
car of of the drive train...
six bolts for the k member... six more for some bracketeria
This is reasonable if a front end rebuild is part of the plan
(bushings, steering linkage etc.) otherwise it might be too
much trouble...
Old Aug 1, 2002 | 03:56 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That happened to me once! The darned rented engine hoist hadn't been properly maintained and serviced by the rental shop. It was down on hydraulic fluid and wouldn't lift that last 2 inches or so to get the engine over the front of the car. We ended up letting all the air out of the tires in order to pull the motor
Needless to say, when they wanted more money because we were late getting the hoist back, we gave them a piece of our mind and left with our cash in pocket
Old Aug 1, 2002 | 06:45 PM
cdogc350's Avatar
Thanks for the info. i managed to get it out by lifting it enough to get it off the motor mounts and letting it swing forward..... dont know how im gonna get it back in, but ill figure it out once the engines done
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
db057
Aug 22, 2015 08:17 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
